Help! Where does this connector go?
Old Jun 11, 2004 | 02:56 PM
Scooter70's Avatar
Default Help! Where does this connector go?
Help!! I have one connector that doesn't have anywhere to go. Speartech modified my harness and I found a place for every connector except for this one. It's near the back of the intake and it comes out of the main harness right where the knock sensor wire does. There's only one wire going into it. Where is it supposed to go? (See the attached picture for a view of it.)
Thanks,
Matt
Old Jun 11, 2004 | 03:12 PM
LS1swap's Avatar
it looks like the oil preasure sensor wireto me, but that has two pins on a 98 did that change for other years???
Old Jun 11, 2004 | 05:40 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
That's what it is. Should plug into your oil pressure sending unit. Or, if you're using aftermarket gauges, just cut the connector off and put whatever terminal is needed for your sending unit. Then you at least have the wire already run to the inside of the car.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jun 11, 2004 | 10:38 PM
Scooter70's Avatar
Thanks John. Oil pressure is done with a 1/8" nylon tube in my car (mechanical gauge). Where is the stock oil pressure sending unit? Does the computer need it or is it strictly there for the gauge? I'll just plug it in and eventually use it whenever I get around to replacing the gauges with nice ones.
-Matt
Old Jun 11, 2004 | 10:45 PM
Speartech's Avatar
It plugs in right behind the intake manifold. It's only for the gauge so you can do whatever you want with it.
__________________
www.speartech.com
