NV3500/LQ4 combo???
The NV3500 can easily be put behind a LQ4,but is slow shifting,won't fit your car without a lot of tunnel mods and will not last if you drive harder than a 90 year old grandmother would.
This trans was offered up until 2006. The hydraulic line quick connect is on the
master cylinder, whereas on the F-body it is on the slave. Rockauto is a good
place to research parts.
The NV3500 is at the limit with the 4.8L's torque. I agree with the previous
comment that it wouldn't last long behind a LQ4.
The GM Synchromesh fluid specified for this trans doesn't give enough protection
to the bearings, I use a 67/33 mix of Amsoil MTF(5w30)/MTG(75w90).
I already had to replace this trans once, if I had to do it again I would put in a
Tremec TR3450, which currently is installed in trucks for the Mexican market,
and is the trans that GM would have used had they continued to offer a
manual trans in the 1500's after 2006. This is technically an import item, and
available only through Rockland Standard Gear.
Edit: After using my truck to haul 1000 lbs for 60 miles at highway speeds, the
trans temperature was above a safe range with the Amsoil, so I replaced it with a
50/50 mix of Redline MT90/MTL, and the trans temp is lower under load as a result.
Last edited by 88bruce; Jun 4, 2016 at 10:26 AM. Reason: Edit: Replace Amsoil trans fluid with Redline.
