What fuel pump
Old Dec 25, 2015 | 02:39 PM
Sleeper3's Avatar
Default What fuel pump
1983 s-10 5.3. What fuel pump and regulator would I use? Thanks for your help
Old Dec 25, 2015 | 04:46 PM
76larkman's Avatar
on mine I just bought a replacement for donor truck(same year) made it fit on my sender. No problem so far. Still in tank so its quiet, cooled by the gas in tank.
Old Dec 25, 2015 | 04:57 PM
Sleeper3's Avatar
I will look into it thanks for your help. I'm most likely going to have more questions. LOL
Old Dec 25, 2015 | 08:55 PM
76larkman's Avatar
Got to thinking for you. Just go to 87-93 s-10 truck tank. It be baffled and have injection fuel pump. Should be easy swap using correct pressure pump on it. Then if you can get some fuel lines from donor, can cut/ modify ends to work. older 5.3 engines have regulator on fuel rail. What year stuff going in? Cable throttle body---can use stock Silverado gas pedal cable 99-02. 03-up was dbw throttle.
Old Dec 26, 2015 | 12:30 AM
Sleeper3's Avatar
Motor and trans came out of a 2000 ext.cab 2wd Chevy. So I can use the gas tank or just the pump and sending unit.
Old Dec 26, 2015 | 10:57 AM
76larkman's Avatar
I would use the pump itself as its rite pressure. Just put it on a s-10 tank sender from fuel injected tank from 87-93 s-10
