Alternator wiring for swap ( microsquirt)
Old Jan 1, 2016 | 04:25 PM
70ssclone's Avatar
Default Alternator wiring for swap ( microsquirt)
How do wire my alt ? 06 lq4 factory alt . I'm at the point were I need to hook it up and I'm not sure where to start and I'm using microsquirt not the factory pc that would have provisions for it
Old Jan 3, 2016 | 11:03 AM
Pop N Wood's Avatar
The computer is not needed by the alternator.
Must be 1000 threads on how to wire in the alternator. Use to have a link to some of the more promising ones but they aren't hard to find. Just forget the computer and wire it up like you have a carb on there.
This looks promising
https://www.holley.com/products/acce.../parts/197-400
Found this in a super chevy article
Holley also offers a specific pigtail (PN 197-400) that plugs into the alternator and is fitted with a built-in resistor so that you can connect this wire to any switched 12-volt wire connection. You can build your own harness if you connect the “L” terminal on the alternator to a charge indicator light or use a 560-ohm, 1/2-watt resistor (Radio Shack PN 271-1116).
Old Jan 4, 2016 | 08:48 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
We have had that adapter on our site for well over a year. 15 bucks free shipping right now.
http://www.shop.bp-automotive.com/se...c?keywords=A21
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jan 18, 2016 | 11:59 PM
dirtylark71's Avatar
Is it still free shipping? I'd take one
