Hydroboost
Old Jan 5, 2016 | 07:14 PM
twel34's Avatar
Default Hydroboost
Tried Posting This in the Suspension and Brakes Section with no luck... here goes nothing for this section.
I am currently in the middle of a 2009 ly6 swap into a 65 Pontiac Lemans. I have opted to go with the Jeep Grand Cherokee steering gear and I am using the ly6 power steering pump. I would like to also upgrade the brakes to a hydro boost system and I have a couple of questions.
1) Would I be able to use a later model hydro boost system from something like a 2000-2006 Tahoe, van, or suburban? Would I run into any issues with fitment or compatibility?
2) I keep hearing about running a mid 90s astro van setup. What makes that system so attractive over a truck or SUV setup?
I plan on having hydraulic lines made with the metric O ring fittings for the JGC box so the lines shouldn't be an issue.
Let me know if I am missing something obvious. Thanks for your help!
Old Jan 5, 2016 | 09:13 PM
67Skylark's Avatar
On my 67 Buick Skylark, I went with jeep steering box and CCP's streetbeast on an LY6. I ended up with the vet alt/ps with bracket. Works great, I'm sure you will be very happy once you get it together. I've read about several setups reusing old parts, I wasn't willing to experiment on the brake system. CCP system is all bolt on, the only messing around is the brake lines and a couple of hydraulic hoses. Good luck, keep searching
Attached Thumbnails Hydroboost-img_20151229_182212.jpg   Hydroboost-dscf2827.jpg
Old Jan 5, 2016 | 10:06 PM
ls1nova71's Avatar
Most hydroboost units are the same, only the mounting is different. The Astro van units are popular just because they're the most readily available. I have it on several vehicles, I like them better than most aftermarket vacuum brake boosters.
