Hooker LS swap header back exhaust
Old Jan 25, 2016 | 11:02 PM
Nabil1967's Avatar
Default Hooker LS swap header back exhaust
I have a 67 Camaro with an LQ4 and t56 magnum. I am using the LS swap bracket, oil pan, and t56 crossmember as well as long tube headers from Holley/hooker.
I was wondering if the hooker LS swap header back exhaust system will work with the 4 link rear suspension? Does anyone have any pictures of this exhaust setup?
Thanks
Old Jan 26, 2016 | 04:45 AM
user 4737373's Avatar
Thanks
It will not be bolt-in installable with a 4-link system; some cutting/modifying of the tailpipes will be required.
Old Jan 27, 2016 | 08:20 PM
Nabil1967's Avatar
Thank you for the reply!
Do you know which motor mount bolts/size to use for the Holley LS swap brackets/clamshell?
Old Jan 27, 2016 | 09:11 PM
Originally Posted by nabil1967
thank you for the reply!
Do you know which motor mount bolts/size to use for the holley ls swap brackets/clamshell?
7/16" x 5.5"
