Nova swap radiator hoses
Old Jan 27, 2016 | 05:42 PM
3 window's Avatar
Default Nova swap radiator hoses
I've got a 5.3 in a '70 Nova with a stock size radiator with the outlet on the lower right side (1.75") and the inlet on the upper left side (1.5"). I also have an LS7 waterpump with the outlet on the driver's side and a straight water neck from Jegs. Not being a fan of spliced hoses, I did a ton of research and ended up successful. The upper hose is a Dayco 71871 (had to use a 1.5" to 1.25" reducer sleeve) and the lower is a Dayco 71904. A little trimming to both, but they both fit very well. Just thought I'd share.
Kind of hard to see the lower, but it's there!
Old Jan 28, 2016 | 10:31 AM
EdyJun's Avatar
Interesting... Where is the reducer ?
Old Jan 28, 2016 | 10:22 PM
3 window's Avatar
The reducer is on the outlet of the waterpump. The waterpump outlet is 1.25" and the hose is 1.5".
Old Jan 29, 2016 | 10:16 AM
EdyJun's Avatar
thanks
Old Jan 29, 2016 | 10:50 AM
hookemdevils22's Avatar
What did you tie steam vent(s) into?
Old Jan 29, 2016 | 11:54 AM
3 window's Avatar
I have a "front" steam tube on the back of the heads with a hose that runs up to a "tee" and ties into the actual front steam tube. A hose will then go to a 1/4npt bung and fitting in the radiator that I haven't welded in yet. It will go just below the filler neck.
Old Feb 1, 2016 | 01:01 PM
jschnell64's Avatar
thanks for the info. Saves me a lot of messing about
