Installing headers - use anti-sieze?
Old Feb 13, 2016 | 09:05 AM
33willys's Avatar
Default Anti-seize
All it take is one seized bolt to start using anti-seize.
Old Feb 13, 2016 | 09:53 AM
Pop N Wood's Avatar
So if one guy never uses it and has never had a problem, than have to ask if it is really needed?
I learned not to use stainless bolts on header flanges. The heat destroys them in short order. Anti seize is no help there.
The comment about heat rating is interesting, didn't know there were different kinds.
As for repairing broken bolt holes the one big advantage of aluminum heads is they can be easily welded. Probably more of a machine shop repair though.
Old Feb 13, 2016 | 11:36 AM
LLLosingit's Avatar
Not necessarily, Depends on the casting and how bad the damage is.
I learned how to take the time to prep the broken bolt/stud for drilling so about 95% of the time I can drill it in a two step process and then extract it in just a few minutes. Some are just a stubborn and take a little longer. This is one reason I like to use studs rather than bolts in certain applications. I've never broke a stud while trying to remove the nut and rarely need to remove the studs themselves.
Old Feb 15, 2016 | 10:11 PM
truckdoug's Avatar
yeah stainless galls really easy. i work on marine stuff and use tons of stainless fasteners. you'll wanna use 316 grade instead of normal 18-8 on exhaust stuff. and copper based high heat paste. or just don't use stainless since it's a car and not worth the hassle or cost, ATMO
Old Feb 16, 2016 | 03:18 PM
TrendSetter's Avatar
how many people smoke their whole lives without dying young? does that mean its not bad for you? is it worth the risk? its completely up to you.
personally, i try to use something on every threaded fastener. either anti-sieze or lock-tite.
