Fuel rail question
Old Feb 22, 2016 | 10:20 AM
Houston_t's Avatar
Default Fuel rail question
Gathering parts for a 5.3 swap in my 96 Tahoe and had a question regarding the fuel line/ rail. My factory fuel system has return and feed lines, the engine i purchased just has a feed line. To ease instillation is it possible that i can just swap out my fuel rail with an earlier rail that has both a feed and return or is there more to it than that ?
Old Feb 22, 2016 | 10:29 AM
CutLS's Avatar
It's probably easiest to run what the truck has if you only want to do an engine swap. If you are going to do new fuel pump and tank stuff, the returnless works good and you'd just run a small return line from a Corvette fuel filter back to the fuel tank.
Old Feb 22, 2016 | 11:04 AM
Houston_t's Avatar
Im trying to utilize the Tahoe's current fuel system witch has a return line, new intake is return-less just figured it would be easier and more cost effective to swap the fuel rail if possible.
Old Feb 22, 2016 | 11:07 AM
tfi racing's Avatar
Just swap the fuel rail,should be cheap and easy to find,most people just toss the truck intakes into the trash.
Old Feb 22, 2016 | 11:09 AM
Houston_t's Avatar
Thanks, just wasn't sure if that was doable or all that had to be done. Problem solved.
