What HiTorque / Small starter for LS3 430
Old Mar 2, 2016 | 09:12 AM
ewingr's Avatar
Default What HiTorque / Small starter for LS3 430
I purchased an LS3 430 HP crate motor from Jegs. I have put Hedman headers on it, the instructions from it saying to order a specific TCI starter. That starter didn't come close to fitting that engine.
So I called Jegs, and they sent me this starter. It also does not fit. There is a tab that comes out from the engine block that is in the way of this starter.
I notice this on Jegs. I have no idea if this will help.
Can anyone provide me info on the starter that should work for this engine?
Old Mar 2, 2016 | 09:24 AM
ewingr's Avatar
Default Clocking did the job...
Never mind on the model of starter. I hadn't even thought about clocking. But about the time I hit send, I did, and it will work.
So now I just need to see if I can figure out how to measure the distance from the ring gear to the front edge of the flywheel to see if I need to shim it. Haven't even tried yet. May not be as hard as I'm assuming.
