lq4 swap into 70 nova
Old Mar 3, 2016 | 09:30 PM
Joseph Williamson's Avatar
Default lq4 swap into 70 nova
Bought my first lq4 the other day. Have a few questions to get it ready to swap into my car. What all on the front can I remove? The egr behind tb is already gone, the fan is taken off now lol, but there's a weird canister thing connected to the passenger side exhaust can that be taken off? Secondly what are the only sensors/functions needed for the motor to run properly?
Thanks in advance guys, this is my first swap
Old Mar 6, 2016 | 11:54 AM
ryanleiker's Avatar
There is more that you need to keep in the wire harness than you take out.
Lt1swap.com is essentially the guiding light for wiring harness information.
Print off the pinouts, buy a Haynes repair manual for the vehicle that your engine came out of. Essentially everything that is emissions related can be pulled.
Old Mar 7, 2016 | 02:05 PM
Print off the pinouts, buy a Haynes repait manual for the vehicle that your engine came out of. Essentially everything that is emissions related can be pulled.
Thank you, I'll check them out
Old Mar 7, 2016 | 03:01 PM
EdyJun's Avatar
Also, take a look at www.stevesnovasite.com.
and you can look at my ports as well. http://www.stevesnovasite.com/forums...9&goto=newpost
Old Mar 7, 2016 | 07:11 PM
ryanleiker's Avatar
Building your own harness is one of the most valuable projects you can do for yourself. You learn so much about how the fuel injection works.
Old Mar 8, 2016 | 07:46 AM
Yeah the harness was my biggest concern with a modern motor but a family member kinda talked me into with benefits of having efi..and now a small turbo build..thank for the replies guys
