A body swap HELP !!!!
Old Mar 11, 2016 | 08:43 PM
user 4737373's Avatar
Originally Posted by 66Chevellelq4
Sorry for the late response. Im using the stock truck accessories, they clear everything just fine with the smaller diameter power steering pulley. I honestly have no idea of my u joint angles. Just kind of shoved everything in and measured for a drive shaft and had one made. Iv taken it on the freeway a few times and no weird vibrations or anything like that.
Thanks for responding back. There's valuable reasons to validate your U-joint working angles that go beyond preventing noticeable driveshaft vibrations. Minimalized U-joints angles provide the most efficient transfer of power and also a higher safe maximum RPM ceiling (the higher their angles, the less RPM your joints can safely be turned at). Lastly, since your U-joint angles are directly tied to your engine inclination angle, optimizing/minimizing them also means your transmission pan, or case of a T56, tucks higher up in the car for more ground clearance and protection.
