Engine coolant temp sensor question
Old Mar 9, 2016 | 01:15 PM
Houston_t's Avatar
Default Engine coolant temp sensor question
There is a large coolant temp sensor on the drivers side of my 2006 5.3, it's going to be in the way of my Dirty Dingo slider mounts preventing them from being capable of making full adjustment. Is there a plug I can buy to block this hole off ? I tried pipe plugs but the thread pitch is not the same. Thanks
Old Mar 9, 2016 | 04:14 PM
ls1nova71's Avatar
That's most likely a block heater, not a temp sender. You can replace it with another screw in plug like the block has on the other side. Probably have to get it at the dealer but can't be too expensive.
Old Mar 9, 2016 | 04:22 PM
Houston_t's Avatar
Yep called the dealer and the ordered it, 9 bucks.
