Looking to buy 1st LS2 or is it?
The seller said he got a wrecked GTO with a running ls2 6.0 with 80k mole. The seller claimed he pulled the 6.0 engine and bolted the ls1 heads, intake, and all bolt on accessories to make the swap a simple " plug and play" install. From the research I did it's not a simple plug and play swap. Would this setup make sense to do? Unfortunately I am almost 3 hours away from the car so I'm trying to do as much research as possible before making the drive/ buy. It's basically the ls2 short block and the remainder is ls1 ....
My Intensions for the car is a weekend toy / driver which may see the track from time to time for fun.
If its an ls2 the knock sensors will be on the side of the block and the cam sensor will be in the timing cover instead of behind the intake.
If it is an LS2 you should have a big 6.0 cast into the back of the block.
Swapping back to LS1 heads makes no sense. Most guys go the other way.
