Mustang Swap Radiator Bracket?
Old Mar 28, 2016 | 09:52 AM
Sube's Avatar
Default Mustang Swap Radiator Bracket?
I know this is probably a silly question but what radiator brackets are these? I'm in the middle of a 5.3ls swap into a 1999 Mustang and I'm using a 4th gen fbody radiator and I'm pretty sure these brackets will work. I just can't figure out what vehicle they came off of. The picture is a LS swapped 1994 mustang using I believe an fbody radiator. Thank you all for looking. And yes I have
Old Mar 28, 2016 | 11:11 AM
Black89Z51's Avatar
Those are stock brackets. They look identical to the ones from my Fox T-bird. That even looks like a stock radiator.
You can see it sort of on the passenger side of my radiator. (I'm using an aftermarket radiator though, obviously.)
Old Mar 28, 2016 | 11:32 AM
Sube's Avatar
I don't think they are stock foxbody brackets. Foxbody have a major bend in them to account for the lip on upper cross-frame. The brackets in my picture are a lot flatter. I actually have a set of stock foxbody brackets and they are no bueno.
These are what stock foxbody brackets look like:
Old Mar 29, 2016 | 08:37 AM
usdmholden's Avatar
Those are stock fox body brackets from a 5.0 car. The 2.3L cars have different brackets but also still work.
Actually the 2.3L brackets have a flange off the side which hangs over the top edge of an fbody cooling fan should you want to capture the fbody cooling fan.
See images in post #27 for pics of 2.3L radiator brackets.
https://ls1tech.com/forums/conversio...ers-etc-2.html
edit - sorry, somehow I missed your reply in post #2.
I see those are different based on the bend. A this point I don't know what they are from.
Old Mar 29, 2016 | 09:49 AM
usdmholden's Avatar
Actually I was sure I'd seen this before but I could not remember where from. Some random Google image searching:
I think they are from a Crown Vic. I did a quick google image search and got these:
http://www.w4wwj.org/Falcon-swap.htm
http://www.nicholsservices.com/vega/radiator.htm
and then this:
1986 87 88 89 90 91 FORD CROWN VICTORIA UPPER RADIATOR SUPPORT BRACKET
Ford # E6AZ-8A193-D
ebay item number 191032932724
http://www.ebay.com/itm/NOS-1986-87-...BSxE52&vxp=mtr
Old Mar 29, 2016 | 10:08 AM
Sube's Avatar
and then this:
Ford # E6AZ-8A193-D
Holy sweet baby Jesus! Thank you man! I've been looking for those stupid things forever! I was going to use some off a 70's C-10 or just make some. I'll be hitting up the junk yard for them.
