LH6 into a-body ps pulley question
I've got a 5.3 from a Rainier for my 71 Cutlass. I think I read somewhere that the PS pulley smaller on these than on conventional truck motors? Is this true? I am wondering if I am going to be able to use it as is or if I will need to swap the pulley.
That's correct, the pump and pulley and bracket on your engine is different than the common truck engine set-up. Your pump is a Type2 pump and your pulley is 5.25" in diameter; the common truck pump is a P-type and uses a 6.75" diameter pulley.
Great! Thanks for the confirmation.
