What are folks using for an air intake?
I suspect Street and Performance has something, but before I just go blindly get something there, I'd like to look around.
The MAF I have is a 5 pin, and it is about 2 1/2 to 3 inches long. Most apparently extends down inside the tube.
Any suggestions?
Is this a common problem? Do you kow if the calibration sleeves actually help? If that's the case, then I suppose someone should lean toward to Spectre unit.
I took a look at those at Street and Performance. They look nice...and quite expensive. Then don't have the calibration sleeves.
What Air cleaners are available for the Spectre? I suppose I could call a vendor and inquire.
One thing that I need to be cognizant of is how much clearance between the throttle body and radiator is needed for specific units. That could be a limiting factor for me. ATM my core support and radiator are not on the frame, so I can't measure now, but I believe the clearance is maybe around 8".
http://www.siliconeintakes.com/
