Fuel Line size requirements
Will this be enough to support the engine? Of course the next step up is 1/2" stainless with a .44" ID, but bending that is going to be fun (Ill do it if I have to). Then the problem becomes, I planned on running the vette fuel filter/regulator, will that work?
Id rather run stainless and never worry about it again vs running plain steel lines.
Thanks!
This is what I have on my LS2. More than enough to support your HP goals. You will not believe how easy the stuff is to cut and flair. I've known more people who have given up on stainless half way through.
