What ignition switch?
Old Apr 8, 2016 | 06:35 PM
AB6DO's Avatar
Default What ignition switch?
Getting close to starting my 5.3/4L60E in 1948 Chevy pickup. What do I need to look for in a new ignition/starter switch?
Old Apr 8, 2016 | 08:51 PM
33willys's Avatar
Several ways to go...local parts store will have a GM knock off ignition switch for under $20 and have Batt, Acc, Ign, Start terminals. Off shore knockoff, single edge cut key and may last a while if you have A/C and such where the load on the switch is higher than original. Ron Francis switch, quality and more expensive. Double edge cut key, GM plug style electrical connections and quality. Your call, just make sure your ignition/ECU has power in the crank (start) position.
