Noid?
Old Apr 8, 2016 | 07:03 PM
AB6DO's Avatar
Default Noid?
See lot of guys say using "noid" to check electrical things. Could some one explain what "Noid" is.
Old Apr 8, 2016 | 07:39 PM
1970camaroRS's Avatar
It's a light that is lit when electrical current is present. https://www.google.com/webhp?sourcei...q=noid%20light
Old Apr 8, 2016 | 08:38 PM
33willys's Avatar
Default Noid light
Use a noid light to check for electrical signal at the injectors. You can buy a box of them to fit different injector plugs for under $20. They will act quick enough to tell if the injector is getting the proper signal. If you are just upgrading to fuel injection, welcome and sell your timing light, dwell meter and carb sync stuff to pay for the new tools like noid light, scan tool and metric tools!
Old Apr 9, 2016 | 08:13 AM
Doug G's Avatar
.....but usually short for solenoid
Old Apr 9, 2016 | 09:58 AM
BLKMGK's Avatar
Actually, I wouldn't sell off the timing light. Even on EFI it can be handy to check ignition synch with standalone ecu to make sure what's commanded is what you get.
Old Apr 9, 2016 | 02:06 PM
AB6DO's Avatar
Default Noid selection
Thanks for the info. Google search brings up a lot of various types and brands. Lyle looks interesting. Any brands recommended over the others?
