Radiator fittings
Shameless video plug sans exhaust while we test fuel pump relay wiring.
For the radiator hose and 4" intake pipe to fit, ideally I have 90-degree elbows on the radiator and water pump attached to a flexible radiator hose that I can route around the intake pipe.
I purchased one of the magnacool flexible stainless hoses with their 90-degree elbows.
It took all of 5 seconds before I sent those back. For advertised as a solution for tight routing hoses, the connectors and the elbows themselves are freaking massive and made more space problems than they solved...plus the plastic covers felt and looked cheap as hell.
I'm hoping you might be able to help me find a better solution. I can't seem to find any true 90 degree rubber elbows that I can plumb a flexible pipe into. I see silicon is an option, but reading around, it seems those don't seal well, and are rather porous to coolant leading to large loss to evaporation over time.
I have found a site that sells steel radiator couplers in a 90 degree bend so I could theoretically weld that onto the water pump outlet, but that doesn't solve my radiator inlet issues, which is plastic. I also struggle to find anything in the 1 3/8" OD size.
I have also seen pictures of some LS swap jobs that are using tiny diameter coolant hoses similar in looks to hydraulic hose? What's up with those?
Any help is appreciated.
--J
