Alternator - Which wires?
Old Apr 22, 2016 | 08:20 PM
BigBadWhitey's Avatar
Default Alternator - Which wires?
Hi guys, I see this thread around and I've read a bunch, but still a bit confused as to a thing or two. Ive got an LS swap going into a 97 camaro - I have an alternator that I BELIEVE is from an LQ4 truck motor, but I am not 100% certain what it is out of.
I have the one wire hooked up into the 4 pin connector (I think its considered slot L on the connector?)
In some places I'm reading that 2 pins on the connector need to be used for some models of alternator? What I seem to have gathered (which may be 100% wrong) is that the pin on the connector (slot L, i think its called again) is the exciter wire, and comes into play when the ECU determines that the alternator needs to charge the battery?
And I read that in some instances, the pin right beside it needs to be wired up into a switched 12v....but I cant seem to find out why.
Someone please steer me in the right direction, I just picked up a new battery and am trying to avoid running it dead a few times to figure out what i need to do!
Thanks
Old Apr 29, 2016 | 02:03 PM
Project GatTagO's Avatar
You're alternator will work fine with just the L terminal connected to the ECU. If you want, you can also wire the S terminal to the main power distribution point. This will improve your overall alternator performance. The terminals at the alternator connector are MetriPac 150 series.
Andrew
