Gary's 65.....Final Chapter
Old May 18, 2016 | 09:12 AM
  #41
Jimbo1367's Avatar
Wouldn't 3:73 and a. A4s low first gear make 1st useless? I always heard w/ 4l60/70, a nice rear gear is 3:42
Old May 18, 2016 | 09:43 AM
  #42
kwhizz's Avatar
Dakota Digital has a module that plugs into the OBD plug and reads all the info from the ECM to feed the Instrument cluster........No need to add additional senders or wires....
http://www.dakotadigital.com/index.c...rod/prd752.htm
Old May 18, 2016 | 09:44 AM
  #43
kwhizz's Avatar
I told Gary to go with a 3:55..........
Old May 18, 2016 | 10:12 AM
  #44
Project GatTagO's Avatar
A 3.42 gear is nice and they tend to be quieter than 3.73s or 3.55s....something about the number of teeth on the ring and pinion gears...or this could be internet legend...
Andrew
Old May 18, 2016 | 10:29 AM
  #45
kwhizz's Avatar
Andrew........What was that sealant you said to use on my Nomad Fuel sender gasket......Guess why I am asking............Cork + ??????? sealant should solve the problem........
Old May 18, 2016 | 11:22 AM
  #46
Permatex Aviation sealer. Napa should carry it.
Andrew
Old May 18, 2016 | 01:15 PM
  #47
1989GTA's Avatar
I think the diameter of the tires will also be a factory in choosing the final gear ratio. For me 3:27 was best with my 6L80 trans.
Old May 18, 2016 | 09:23 PM
  #48
CattleAc's Avatar
I run a 3:73 gear in the LS powered A-body wagon in my sig. I thought the same thing, but, I run a 28" tire and it actually works very well. First gear is very "usable"...
I thought my mileage would suffer also...but with a LS-6 cam 5.3, I can knock down 20-23 on the highway.
I think the 3.73's will be bitchin' in that big beautiful B-body.
Old May 19, 2016 | 06:26 PM
  #49
kwhizz's Avatar
We had two issues than needed to be resolved......#1....Fuel gauge didn't work.....ended up being a solder joint that failed inside the sender (had to pull the tank down to find it)......#2....Intermittently the starter would just "Click" "Click" like the Battery was dead....Humm!!......After checking everything out......the new starter was "Junk".....replaced the starter with a new one and everything is now perfect .............Then......After removing the Dead weight in the Engine compartment.......The front end of the car was now way too high......Gary adjusted the Coil-over shocks to lower the front end down to where it was before.............anyhow.........Here's a Video of the car running.......
http://vid13.photobucket.com/albums/...y/IMG_7428.mp4
Old May 19, 2016 | 06:34 PM
  #50
showdog75's Avatar
Not sure what it had in it for a big block but I'm curious what you and Gary think of the big block verse LS power. I've got a buddy that has a 65 Biscayne and I'm trying to talk him into a LS swap instead of a big block.
Old May 19, 2016 | 06:39 PM
  #51
kwhizz's Avatar
No Comparison.........LS all the way...........
Old May 19, 2016 | 08:06 PM
  #52
ls1nova71's Avatar
Hmmm, didn't see that answer coming......
Old Aug 14, 2016 | 08:15 AM
  #53
Jimbo1367's Avatar
Taller tire. What trans are you running?
20-23 MPG......again, what trans? Even with a 4L60, thats really good with 3.73s IMO
Old Aug 14, 2016 | 08:48 PM
  #54
CattleAc's Avatar
I run a 275-60-15 tire, and yes I run a 4l60e.
Again, I was a little concerned about the 3,73"s being to low, but now that I've ran them for a couple years, I'm very happy with both the mileage and the performance...
