LT1 24x harness for an LS1??
Old May 10, 2016 | 05:13 AM
Greg88's Avatar
Default LT1 24x harness for an LS1??
Can someone tell me if this 97 lt1 24x will be close to a direct bolt on with a 99 ls1 engine?
Old May 10, 2016 | 06:47 AM
Blue89Bird's Avatar
no...
Old May 10, 2016 | 12:28 PM
MorePSI's Avatar
What are you trying to do exactly? The LT1 24X harness is meant to convert an LT1 engine to coil near plug ignition to alleviate optispark issues as well as give it the 0411 ecm which is more powerful as well as better supported compared to the LT1 unit. The connectors used and harness layout are generally not the same as they would be for an LS1
Old May 13, 2016 | 06:52 AM
Greg88's Avatar
Just was trying to determine how easy of a swap an ls1 was going to be into my car. (Harness wise). Obviously the 24x harness is no where close to what I need! Thanks guys!
