need help with water pump
Old May 21, 2016 | 04:43 PM
xenaskyy's Avatar
Default need help with water pump
I have a Lq9 put a 102mm lsx intake and 102mm throttle body but the throttle body is hitting water pump so im trying to figure out what water pump to use so that i dont have to swap all the pulleys if possible i need the tube on water pump to come out of the middle of water pump
Old May 21, 2016 | 07:56 PM
tfi racing's Avatar
Have a look at the 2010+ Camaro pump,should do the trick.
Old May 21, 2016 | 09:25 PM
xenaskyy's Avatar
Thanks
Old May 22, 2016 | 02:15 PM
xenaskyy's Avatar
What is best under drive pulley set up for an lq9?
