No throttle
Old May 31, 2016 | 08:47 AM
trobert3's Avatar
Default No throttle
Swap 78 nova has been running over a year , everything from 09 Silverado 5.3 with 6l80. Took car out yesterday Memorial Day running fine get on freeway , then I noticed car wouldn't shift out of 4th gear at this time I have throttle so head home, 5 blocks from home and no throttle but engine still running. Finally make it home, disconnect battery for 10 minutes reattach, throttle responds so I drive around the block goes through all six gears , then no throttle response again so I repeat process with battery but same results after a short drive no throttle.
Old Jun 1, 2016 | 06:51 AM
JoeNova's Avatar
Restricted User
I think I would have converted to drive-by-cable already.
When the throttle stops working, check for codes. You might be losing TAC signal or ground (it was ground in my case).
Old Jun 1, 2016 | 07:05 AM
trobert3's Avatar
I pull code po641 open circuit. So am checking the harness and grounds.
Old Jun 1, 2016 | 09:51 PM
DW SD's Avatar
http://www.camaro5.com/forums/showthread.php?t=360258
couple threads out there about back feeding sensor voltage.
