L92/4l80e
Old Jun 4, 2016 | 03:17 PM
kainedogg's Avatar
Default L92/4l80e
I picked up a cheap L92 ($600) yesterday and am thinking about tossing it into my '70 Skylark using the new Holley A-body kit. That aside, I don't have a harness yet, nor pedal. I do however have the truck intake, rails injectors and throttle body, an extra E38 ecm from my Chevelle project. Now for my questions:
Who makes a good 58x harness
I have a 4l80E to mate to the L92. Do I need to source a TCM or can the E38 be used to shift the 4l80e?
Should I source a pedal from an L92 based truck or buy an LS3 pedal/throttle body combo
Can I use the truck maf or is an LS3 map preferred.
That's about it. My plan is a poor mans ls3 in the Skylark. It is a convertible and I just want a nice 500hp cruiser. That means removing the VVT and DOD and going from there. I expect the project to start after the summer.
If there are any guys local (Tampa) I would love to check out your swap.
Attached Thumbnails L92/4l80e-photo-2.jpg
Old Jun 4, 2016 | 07:33 PM
truckdoug's Avatar
i think the e38 can control a t42 trans controller so that oughta work. maybe post in the diagnostics and tuning section though to be safe.
Old Jun 4, 2016 | 08:40 PM
kainedogg's Avatar
Roger that
Old Jun 5, 2016 | 02:57 PM
Sebtarta's Avatar
BP Makes a very good harness.
http://www.shop.bp-automotive.com/LS...r-Kit-1324.htm
I bought mine from Bill, and it has been great since.
GM Performance sells a kit as well, Speartech, PSI. Or you can make it yourself. You will need a TCM with this combo.
I live in Orlando, if you are around let me know.
