Pnp range sensor wiring
I am currently doing a 5.3 4l60E swap in a 93 c1500 I am bypassing the the nss on the truck itself and wanting to use the one on the 4l60E since I will be wiring the reverse lights up to it I am going to use a relay between the pnp and the starter I want to make sure I wired it right or if there is a better way as of now this is how the relay is wired #30 is the purple wire from ignition switch,#87 purple wire to starter solenoid, #86 to green wire at pnp output park, #85 ground haven't checked to see if would crank yet trying to finish up wiring and wanted to make sure before.I tried it
