data link connector Gen5 info needed
Old Jul 1, 2016 | 08:56 AM
custom 68's Avatar
Default data link connector Gen5 info needed
hello all, I am wiring my gen 5 engine and have most of it sorted out. I am to my obdii connector (data link). What wires do I need to hook my HP Tuners up with? The diagram shows two (1 and 2) GMLAN highspeed plus and minus I was going to run both but my generic connector didn't have enough wires, I can add some but didn't have the right connectors on hand. Can I get by with just hooking up the number 1 GMLAN along with the other 12 volt, ground (serial and other)?
I may also eventually use a CAN bus type gage system but that is down the road.
Thanks a ton.
David
Old Jul 1, 2016 | 02:48 PM
EFIHARNESS's Avatar
You need 5 wires in the obd connector,
Gnd in pin 4,5
Battery +in pin 16
Gmlan + in pin 6 (E39,E92= J1-39)
gmlan - in pin 14 (E39,E92=J1-40)
This is where you pick up can data for your gauges. Steve
Old Jul 1, 2016 | 02:53 PM
custom 68's Avatar
Thank you Steve, that is where I was heading but I got to second guessing what all was needed.
Will the hptuners also communicate and tune and all that stuff thru the Gmlan?
Old Jul 1, 2016 | 10:37 PM
EFIHARNESS's Avatar
Yes.Steve
