Noisy LS1
Old Jul 6, 2016 | 05:29 AM
freda155's Avatar
Default Noisy LS1
The first minute after cold start I have piston slap, but it goes away. I did not enter this project to bother about piston slap, but so be it. Win some, lose some. When warm there is still noise, but different noise. It is not knocking (as in rod or crank bearing fault). It is similar to a cold starting engine before pressure builds up in the lifters. So I am hoping that is it. It sounds loose.
Only at part throttle and around 1000 rpm. Which equals to almost 100 percent of daily driving.
What should I do, replace all of the lifters or what?
