C5Z06 LS3 Engine Swap Running Hot
The problem was with the port size of the two fittings on the passenger side radiator top section on the new Ron Davis Radiator. One is the return from the top of the block and is a small hose (1/4"), the other is the expansion tank feeder hose and is a bit bigger (3/8"). I noticed that the expansion tank had a lot of turbulence (flow) going through it. This bothered me as, at the time not knowing what the radiator passenger side tank looked like inside, it seemed wrong. I opened the old original radiator and these ports go to a closed box and are tiny openings (1/16" and 1/8" maximum I estimate). So I put some vice grip clamps on the hoses to partially close them off, in particular the large one to the expansion tank untill the flow into the expansion tank was pretty low. I went for a drive and the temp was rock solid at around 198-201F under all driving conditions. I am baffled as to why Ron Davis would send me fittings with such large porting. I will call them on Monday and discuss. If I was not carefull and cautious I could have overheated my car. A decent portion of the coolant flow was shortcutting across the top of the radiator through the expansion tank.
