1999-2004 LS Swap Help?!
I had a 05 Gto and a 99 Mustang GT.
The Mustang was my daily, I sold the gto now I'm wanting a LS Mustang.
I'm buying a wrecked ws6.
LS1/T56
I'm looking for any advice you guys can lay on me.
I will have the complete donor car, trying to Salvage as many parts as I can.
Few things I need help with.
-Fuel Setup, I know the ls is return style and the Mustang is returnless.
-The clutch, the ls is hydraulic and the Mustang is cable so I'll need insight on that aswell.
-Will the T56 line up where the stock transmission lined up or will I have to modify the interior?
I know everyone says the guages can't be used, who sells cheap clusters for swap cars? I have Pro Comp Guages but they are a different size then the factory holes that's my only problem.
-I definitely need help on the wiring, is it cheaper to use the ws6 wiring or better to buy a plug and play? If plug and play who sells them.
I'll be using a Team Z kmember and motor mounts.
What about trans mounts.
Really any advice will be appreciated, thanks in advance.
I can't use the Fbody Clutch Master?
Also do you have a 6speed? The real condition there is the hydraulic setup and getting it to work.
If you are using the t56 can I get a Interior picture?
