Torque app and tans temps
Old Sep 24, 2016 | 08:45 AM
jozw30's Avatar
Default Torque app and tans temps
Posted here because I see people use the Torque app a lot.
Anyone getting the transmission temperature PID to function on a 4l60?
I loaded the PID and have a gauge on the screen but it doesn't function.
I went went with the Troque APP specifically for this feature. Even bought a cheap phone just to run it as I use Apple for everything.
Can't seem to find whether the 2006 LS2 and 4l65E I have even make that info available to the OBDII....?
The guy that did my harness has no clue.
Old Sep 25, 2016 | 03:00 AM
truckdoug's Avatar
i had it function for about a year when i ran a 4l60e
eventually i switched phones and when i downloaded the app again the trans temp was gone, along with gear indicator and converter slip %
Old Sep 25, 2016 | 10:28 AM
33willys's Avatar
I found a Torque forum which demonstrates how to add features and one is the GM trans monitor. Have not done it myself yet but will investigate and report back.
Old Sep 25, 2016 | 06:20 PM
33willys's Avatar
Default Trans temps app
Found it! If you tap the background to add a gauge, scroll down the list toward the end there are two for trans temps, method 1 and 2. Have not tried them yet because I'm down while putting carpet in.
Old Sep 25, 2016 | 09:06 PM
jozw30's Avatar
33willys, I have loaded the GM trans temp PIDs and created gauges for them, they just don't do anything once you start the car and connect to the OBDII.
