LNC-2000 issue
Old Sep 26, 2016 | 01:03 AM
blacknyellow's Avatar
Default LNC-2000 issue
I've got the lingenfelter lnc-2000 unit and I love or loved it. It worked flawlessly for some time but just tonight it wont "2-step" everything else with the truck works fine but I found that it wont "2-step" at all. The red power light begins to flash at 1500 rpms and it will not "bang out" at the set rpm on the unit.
Any help is appreciated. Thanks
Old Sep 26, 2016 | 08:02 AM
silent_assassin's Avatar
Know it sounds dumb but move the **** back and forth and make sure it's not stuck between 2 numbers.
Old Sep 26, 2016 | 01:18 PM
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default LNC-2000 activation
If it is blinking red when you achieve 1500 RPM that indicates the unit is set for a 1500 RPM 2-step engine speed. If that is what you have the dials set for then that part is working correctly.
It has to be blinking green for it to limit the engine to that RPM. If it doesn't blink green that likely means you don't have the activation working any more. Activation is achieved by connecting the yellow wire to +12v or the green wire to ground when you want the 2-step to be activated.
Old Sep 26, 2016 | 02:23 PM
Im an idiot, I was a little "crosseyed" last night and had the x100 and x1000 settings backwards.
I apologize for wasting yalls time.
