ATS or Meanstreets Performance clutch master bracket??
Old Oct 13, 2016 | 05:46 PM
GonHuntin's Avatar
Default ATS or Meanstreets Performance clutch master bracket??
Looking at both of these options for a '68 camaro T56 install and was wondering if one is better than the other?
I plan to use the stock master cylinder and throw out bearing from a 2002 Trans Am donor car.
Another question, how is the clutch rod hole in the firewall sealed when using these brackets??
Old Oct 14, 2016 | 02:05 AM
Jimbo1367's Avatar
Have you considered DSE's bracket?
Old Oct 14, 2016 | 08:34 PM
chuckd71's Avatar
They are just plates that hold the master at an angle; other than bling I wouldn't think there could be much difference. Considering where it's located I doubt anyone will ever see it, but should you need to change the angle for any reason the ATS would be an easy cut/weld.
As for sealing, when I went to OReilley to buy a strip of that A/C sealant (dum dum dape?) they just gave me the whole roll, so I'm going to use that I guess.
Old Oct 16, 2016 | 10:40 AM
Jimbo1367's Avatar
I was thinking cost. Possibly better looking too.
Old Oct 16, 2016 | 03:38 PM
GonHuntin's Avatar
The meanstreets bracket is machined aluminum and, although it is more expensive, I think it's the best looking. The ATS bracket is commonly used but I haven't found any info on how people are sealing it to the firewall at the lower angled portion??
