Help with O2 sensors wiring
I used the 2004 wiring harness which was originally Blue/Green ECU and repined the connectors for the Red/Blue 0411 ECU.
Ive flashed in a 2001 Silverado k1500hd 6.0l Vin number into the 0411 ECU.
Problem is the oxygen sensors always read 440-450mv. Ive checked all the wiring and everything is good and pinned correctly and I do not have after cat o2 sensors or the wiring to them. They are new AC Delco sensors. Ive looked at the pinout for the 02 camaro and it does not show O2 heater grounds going to the ecu but the 01 silverado does. I thought they were the same ecu. Do I need to pull the heater grounds and ground them to the block instead of them going to the ECU?
See https://ls1tech.com/forums/conversio...g-diagram.html
