Ls1 t56 to 65 mustang...
Old Nov 5, 2016 | 02:27 PM
65ls1!'s Avatar
Default Ls1 t56 to 65 mustang...
Shorted something out 2day. Hosed off the car in the morning because windows were foggy and some frost. Put key in ignition turned key and heard the fuel pump prime, pressed clutch in and turned key and heard a pop or 2. Sounded like it came from ignition switch though...Now insert key and fuel pump does not prime, car does not crank...I switch my fan relay switch with the fuel pump relay...still not priming or cranking...also ecu will not connect to torque OBD...Going to be a fun weekend...any ideas?? Going to check power to ecu and ohm out the 2 relays just incase they both went bad...I hope I didn't fry the pcm.
Old Nov 6, 2016 | 03:10 PM
Project GatTagO's Avatar
Blown ignition switch? Don't you know how you wired it? Lol...
Andrew
