LS to Foxbody w/hydroboost question
I would either hook the lines up and use the hydroboost, or remove it completely and just run the mastercylinder on the firewall. Thanks
My goal is to install another fitting onto the power steering res as I have heard of guys being able to do that as long as it is in the correct place. Unless you guys think Ting into the low pressure line might work and avoiding taping into the res to install a third line. If anyone has any suggestions please let me know as I am trying to avoid redoing my brake to fit a older vacuum assist.
Work flow chart I found online....
Nt sure what year this pump on the right came from but it is set up for a Hydroboost. Anyone know what years had hydro boost that would work with LS truck style brackets?
How I plan to lay it out
