P1518 please help please
Old Dec 20, 2016 | 12:35 PM
Robert Rizzo's Avatar
Default P1518 please help please
PLEASE HELP
installed new Throttle body. in 1989 LS swap that has been fine for two years. New fuel pump. Tac Module Wire to New Pedal. and engine runs well and idle well. I start to drive and when rpm hits 2400 or so throws cod P1518 and throttle stops working.
Old Dec 21, 2016 | 06:36 AM
Can anyone refer me to someone who can assist?
Old Dec 21, 2016 | 04:36 PM
ls1nova71's Avatar
What year is the engine and what engine is it? Was it DBC before?
FlatBlack's Avatar
1989 LS Swap? What year/size is the engine?
Old Jun 1, 2018 | 08:53 PM
Luis photos's Avatar
Did you ever fix it?
Old Jun 1, 2018 | 09:08 PM
Probably not.....
Old Jun 1, 2018 | 10:25 PM
Damit I have the same problem and I can't figure it out.
Old Jun 1, 2018 | 11:20 PM
33willys's Avatar
I can only offer what happened to me with the same symptoms. Turned out the tune was not compatiable with the TAC and APP. Once I upgraded to match the tune everything fine.
Old Jun 2, 2018 | 03:21 PM
By tune do you mean like removing vats and emissions? Cause that's wat I got on my ecm mayb he didn't do it right or something?
Old Jun 2, 2018 | 08:06 PM
33willys's Avatar
When mine was reflashed to delete VATS and other stuff the tuner updated to the latest GM which was an '05 tune and it was not compatiable with my APP and TAC. Drove me nuts for a month, borrowed a friend's pedal and all worked fine. He still wants his pedal back. Bottom line is for ME the APP, TAC and tune all have to be one with the world or it keeps going into the limp mode above about 30 percent throttle.
