Electric fan control
Old Dec 23, 2016 | 07:24 PM
CJ-Z's Avatar
Default Electric fan control
I've searched and can't find the answer. I have a 01 5.3 planted in a Toyota landcruiser . Everything is great except for the cooling fan . It will come on at set temp, but will not turn off until key is turned off. Believe we have a 195 stat, fan is set to come on at 210 & shut off at 200. I can use hp tuners scanner vcm controls and turn fan on & off no problem....... Any help would be appreciated, thanks , RJ
Old Dec 23, 2016 | 08:04 PM
Project GatTagO's Avatar
Is your relay sticking?
Andrew
Old Dec 23, 2016 | 09:06 PM
CJ-Z's Avatar
Don't think so , because I can turn the fan off with the vcm controls....
Old Dec 24, 2016 | 05:57 AM
1970gobg's Avatar
Does it come on as soon as you turn the key on or at 210?
Old Dec 24, 2016 | 06:01 AM
1970gobg's Avatar
Sorry it comes on at set temp. I should read slower.
Check continuity to ground when fan should be turning off. Maybe the relay is getting a false
Ground signal from some somewhere else.
Old Dec 24, 2016 | 08:44 AM
JoeNova's Avatar
Restricted User
Change the off temp to 195 and reflash.
