4.8L LR4 swapped E36 - Suggestions needed
Bought a LR4 under the impression it was a 5.3L and made the rookie mistake of not checking the pistons before buying. Once I started tearing into it to check the health of everything, I committed to swapping the 4.8L in. Rather than just save a bit of money in the long run and swap in a larger, more popular engine, my intentions are to use the LR4 as my own personal test bed. I've always loved higher revving engines, so the idea of a high revving, short stroke V8 in a sport coupe appeals to me. Long term plans though.
While I'm working with my local machine shop, I'm trying to plan out what parts and bolt ons I want to pursue for the first iteration of my build. The chassis and rear end are good to around 450 horsepower so I have a little bit of head room. Since the 4.8 appears to be the black sheep of the Gen III family, there isn't much information on camshaft recommendations well compiled.
I'd like to ask the gurus of LS1TECH what their recommendations for a mild, streetable camshaft for the LR4. I don't mind dealing with a little bit of discomfort for a summer daily. The engine will have long tube headers (Sikky brand) and my intent is to have as free flowing of an exhaust to an x-pipe and then straight back. No matter what camshaft I choose, I know I'll need stiffer valve springs (at least LS6) to accommodate the larger lift. The car currently has approximately a 3.23 rear end in it, but I intend to swap that next winter when I reinforce the rear subframe.
Aside from a camshaft recommendation, I'm looking for some insight into rev limit suggestions/limitations for the stock LR4 rods. I'm planning on swapping ARP rod bolts in as I rebuild the engine, but would like a guestimate of what I should have my tuner set my rev limit to.
Appreciate any help or insight I can get regarding these two items. Thanks in advance.
What are your plans for a trans and mounts?
I have a set of used NAHR swap headers for sale if you haven't bought from Sikky yet.
Andrew
Looks like the diff is a 3.15 unit. Long term plan is to replace that with a stronger, lower final drive diff.
Transmission is going to be a T56. Can't see myself not rowing my own gears. I bought engine mounts from Ckpitt; He's on here and on BF. Mounts are top notch and quite affordable. Headers were sourced from Sikky. Really impressed with their build quality. We'll see how fitment ends up.
GatTagO, Brian Tooley Racing suggested a similar duration and LSA, so glad to see there's some overlap in cam suggestions. Do you have any experience with BTRs camshafts or cam kits? Glad to see an improvement in rod bolts will get me to the rev limit I'm targeting.
My thoughts on the rev limit is purely anecdotal. I had a RX7 with a LS6 and I installed Katech (no longer available) rod bolts. I am pretty sure the LS6 rods were nothing special and I beat the **** out of that engine and it never skipped a beat.
I also wouldn't be in any hurry to swap out the 3.15 R&P. Drive the car...you may really like it. I imagine you will run a fairly short tire and that will help with the overall "ratio."
Andrew
Based on my research so far, all the stock GM rods seem to be pretty capable, both in speed and torque carrying capacity, with a good set of rods and bearings. I don't intend on beating the **** out of this, yet that is, so a small investment for peace of mind seems reasonable.
I wouldn't worry about the rods. Keep the rev limiter at 6500 and enjoy the ride.
Andrew
Good plan, I wish I had gone that route at some point, I think I'd be more motivated overall had I focused on getting the car running first.
Idles good and makes lots of 4000+ RPM Power on a 4.8.
Rods shouldn't be an issue. The stock 4.8 rods are the only stock gen 3 rods to break the 1000whp mark. The stock rod bolts should be good to 6800 without issues thanks to less piston speed.
Do you have any dyno numbers of that cam in a 5.3L?
Andrew
His truck made 270whp/305 ft-lbs on the dyno stock with an ebay intake and a fresh oil change and some plugs. I think he also had a dual exhaust on it but it was only replaced behind the Y-pipe.
After cam, springs, and tune he made 315whp with the same peak torque. Only revved it to the stock limiter. Could have probably squeezed more power/torque out of it, but I didn't increase timing, only shifted it around a little.
When I get my hands on a 4.8L I will be running a 227/230 .605"/.608" 113+3 cam in it. I will be replacing the stock small valve heads with a set of 241s I have laying around, add some decent springs and basic pushrods and it should sing pretty high.
Then boost.
Then boost.
Does anyone have any experience with the Summit Racing LS lifter kits? Are they worth the cost savings compared to the GMPP/Chevy Performance lifters or similar aftermarket ones (comp, etc.)? What about the GMPP high capacity oil pump compared to a similar Melling unit?
You can go pretty far on some LS7 lifters with the right supporting components.
