Another LS Corvette
Old Jan 10, 2017 | 12:59 PM
CLJonesVette's Avatar
Default Another LS Corvette
Hello All,
I fell into a really awesome deal a well running LQ4 out of a 2003 Silverado. This engine came with all accessories and computer, it is a drive by wire. I traded an item that I built for around $500. The individual only needed the transmission and didn't need the motor.
I will be planting this into a 1982 Corvette Base. I can only do one thing at a time on it because I work a gazillion hours per week.
I am planning on keeping the engine as stock as can be, I'm not taking it to the track or planning to race on the street. I would like to know if it is possible to use the 700r4 even though its not an electronic transmission? Do I need to do anything special like flashing the PCM or repining for the non electric trans?
If so what is the most applicable mounts to use? Also do I need the ones that move the engine forward, stock, or backwards?
I know that this is a redundant topic so thanks in advance for the direction.
Ed
Old Jan 10, 2017 | 02:26 PM
garys 68's Avatar
I've got an 02 LQ9 in my 68 vette, absolutely love it.
Yes, you can use the 700R4, but you need cable throttle body and a TV cable adapter. If you've got DBW, you need the ecu tuned for cable and the harness modified, IAC added.
Most tuners an program for a non electronic trans.
Using the 1" setback mounts will put the trans close to the original position and will allow you to keep your driveshaft.
Oh yeah, the LQ4 intake will never fit under the hood, start looking for an LS6 or LS1 intake.
Old Jan 10, 2017 | 02:50 PM
Default Thanks for the info
Gary thanks for the information did you keep the engine stock, or did you do some things to it? I did start looking for a LS6 intake as you suggested.
Originally Posted by garys 68
I've got an 02 LQ9 in my 68 vette, absolutely love it Yes, you can use the 700R4, but you need cable throttle body and a TV cable adapter. If you've got DBW, you need the ecu tuned for cable and the harness modified, IAC added.
Old Jan 10, 2017 | 04:17 PM
garys 68's Avatar
I was planning on heads, cam, etc but loved the power and reliability of the stock engine. It already over drives the stock wheels, suspension with the Richmond 6 speed I put in with it.
A couple other things to consider. Oil pan (corvette or F body, I'm using the batwing), accessories (Holley brackets work great, f body fits too), exhaust (I'm using 02 Z06 manifolds, they clear everything and flow great).
Old Feb 19, 2017 | 01:10 PM
Default Accessories
question about the accessories from the lq4/9 did you sell off the originals or were any of the stock accessories and mounts useable?
Old Feb 20, 2017 | 08:16 AM
garys 68's Avatar
I kept the alternator, tossed the bracket and made my own. No PS. Made a bracket for aftermarket sanden compressor (Vintage Air) similar to the Kwik bracket.
Either Kwik or holley will fit in a vette and are spaced for vette, f body, or truck. You will need a small PS pulley with those though.
