Another Where is my Ls1 from
Old Jan 12, 2017 | 10:43 AM
Gav's Avatar
Gav
Default Another Where is my Ls1 from
Hi,
Happy New Year all.
I have got to give a year for my Ls1 engine.
I dont know where it came from but here is all i can find without removing gearbox etc:
On front of engine by water pump VF032900142 is etched.
I have no numbers by my oil filter like the majority of you.
From here http://www.ls1.com.au/forum/archive/.../t-156830.html am i guessing that this would be a 2003 engine??
It has LS1 heads 241 casting with K217 477 inscribed on them (Porters stamp??)
The block casting is 12561168....LS6 block with LS1 heads??
Any ideas if 2003 is right and what car would this have come from and did they have 241 heads or have these been put on it??
The PCM is not the original.
Regards
GAv
Old Jan 12, 2017 | 12:28 PM
JoeNova's Avatar
Restricted User
2003 Corvette LS1?
Old Jan 12, 2017 | 02:20 PM
Gav's Avatar
Gav
Thanks Joe, looks like 2003 engine then.
Regards
Gav
Old Jan 12, 2017 | 07:01 PM
Project GatTagO's Avatar
Is it cable or drive by wire? I am pretty sure that 2002 f-body LS1s used the LS6 block...
If it is DBW, then 2003 Corvette sounds about right.
Andrew
Old Jan 14, 2017 | 04:56 AM
Gav's Avatar
Gav
Hi,
not stock tb fitted, its hoĺley 90mm.
i am from uk btw. Could it also be a monaro? As these are just as easy to get in the uk...
regards
gav
Old Sep 14, 2019 | 07:24 AM
Gav's Avatar
Gav
Sorry to bump this but should have started another thread.
With my block being potentially 2003, would this have been fitted with a standard ls1 timing chain or did they stop making these then and would have fitted LS2....?
Its an engine out for me...big job to change.
Should i be worried with ls1 chain 224r cam and pac1219 springs??
Regards
Gav
Old Sep 14, 2019 | 11:47 AM
The LS2 came out after your engine was built. The LS2 chain is a direct replacement for your LS1 chain. If there are very many miles on your engine, a new LS2 chain would be cheap insurance.
Old Sep 14, 2019 | 12:32 PM
Gav's Avatar
Gav
Hmmm,
Dont know mileage or history...
Would a compression test tell me anything about mileage done?
Regards
Gav
 Michael S. Palmer
