Quality Wire Loom?
Andrew
I used it on my Nova and other projects.. and cost a lot less than the major brand stuff.. (Painless, etc)
BC
You can buy it at Amazon, CableOrganizer, WireCare and McMaster Carr, among other places.
Tipsy
The shrink tube has heat activated glue in it, & does a super job of keeping the looming where it should be.
A little forethought when putting the harness together, will allow you to put the shrink on, before the terminals are put on.
When we cut the looming, we use a "mini torch" to melt the loom ends, so they don't unravel. Just a quick pass and it's done. We use a hair dryer to set the shrink tubing. Open flame is prone to melt the loom.
As said above I used a mini-torch to melt the ends after cutting, if you don't it will unravel on you. You could also use a hot-knife to accomplish the same thing.
