Vacuum port usage
Old Feb 2, 2017 | 08:55 PM
LSX_Corolla's Avatar
Question Vacuum port usage
I have swapped an LQ4 into my car and I have searched for some sort of guide on which ports and holes had to be used but was unsuccessful... I have an LS1 intake and T/B and it has a small cam. Car has no power brakes or steering... What vacuum ports on the engine, t/b and intake need to be hooked to other ones and which can be capped? Do I have to use any of them? can I ju put a small filter in place of PCV valve?
Old Feb 3, 2017 | 08:36 AM
simman22's Avatar
Since you don't have power brakes the only one you will need is the PCV if you decide to run it. Some cars need a vacuum to run the HVAC as well. Everything else can be capped off. The truck intakes have a vacuum line that goes to the regulator as an FYI.
