'02 f body connector...recognize this??
Anyone give me a hint where the connector plugged in??
Thanks
This link will give you all the info you need on your harness pcm pinouts.
http://lt1swap.com/2001_PCM_CONN_PINOUT.htm
This plug is part of the engine harness and the bright green and brown wires from this plug go to the right side of the trans in the middle, my research says the plug at that location is the reverse light switch.
I am well aware of LT1swap.com and the pinouts at that location, I'm not looking for PCM pinouts. I have spent lots of time on that sight and have not found the info I'm seeking, may have missed it, but I don't think so.
Thanks
http://www.lt1swap.com/ls1_wiring_ha...connectors.htm
