C4 5.3/4+3
what were the plans for an intercooler?
I made a new brace that mounts on front side of frame just in front of intercooler, a few inches further forward than stock.
Any pics of the intercooler or info on size? Trying to figure out what size I need. Procharger makes one that fits over the factory radiator but want $800-1200 just for the intercooler.
Placement seems to be the hardest part for a C4 considering there's not many options for air flow.
They're $200 or less. Exits over top of radiator, and is a straight shot into the 5.3 truck throttle body with a piece of 3" intercooler pipe thats no more than a 12" long.
dont think there here will be cooling issues with it mounted in front of the radiator?
Damn I've got a large case truck alt but hopefully it doesn't take much massaging to make it work.
Hows your C4 coming along? Any pics?
I was planning on using the truck manifolds.
To joenova-did you remember what lines you used?
I was able to get the truck bracket to fit by cutting the lower part off but I think the pressure switch on the pump is in the way-what did you do to remedy this?
Did your pump have the pressure switch? Did you have to change the piece out to compensate for the C4's lower pressure?
Any issues with just plugging the hydroboost line?
