Clutch for lsx/t10?
Old Feb 23, 2017 | 08:49 AM
sean byrd's Avatar
Default Clutch for lsx/t10?
5.3 and will be using a 4+3(T10) w/ 26 spline.
I've got a 621 bellhousing, sachs 1050 FW and the LS7 pilot bearing.
Does anyone know which pressure plate and disc I need? Also anyone happen to know if my stock TOB and clutch fork will work?
Old Feb 23, 2017 | 09:53 AM
Accrdwgnguy's Avatar
A 11" 26 spline GM clutch. I plan on using a Luk 04020 which is a 11" 26 spline clutch for lots of older GM applications. Look it up for a 1980 Camaro Z28.
Old Feb 23, 2017 | 10:24 AM
sean byrd's Avatar
Awesome thanks! $93 from jcwhitney.
Old Feb 23, 2017 | 05:03 PM
Project GatTagO's Avatar
Originally Posted by sean byrd
....Also anyone happen to know if my stock TOB and clutch fork will work?
Probably. You may need an adjustable height pivot to get the geometry right. There are also different height bearings, so it will probably be fairly easy to mix and match and get stockish parts to work.
Andrew
