new here! Would Like some info/help
Old Feb 25, 2017 | 05:24 PM
j_christ's Avatar
Default new here! Would Like some info/help
hey guys, I was looking for some help with an ls2 swap. I have an 86 chevy 2wd pickup and I'm running a porterbuilt level 3 front dropmember with tubular a arms. i found an ls2 motor out of a 2005 GTO an was wondering if you guys could help me out with info on everything i will need to do this swap.Also any problems you might have encountered. I have limited knowledge on mechanical things, so bare with me. I've been doing some research, but i just want to make sure i have everything lined up. I've seen a lot of things about swapping wiring harnesses, do they make pre made ones that you can buy or do you have to reconfigure your own. thanks in advance.
Attached Thumbnails new here! Would Like some info/help-img_7350.jpg
Old Feb 25, 2017 | 08:16 PM
Project GatTagO's Avatar
Cool truck. I believe Holley makes all the swap components for that truck.
For the wiring harness there are several forum sponsors that will build you a standalone harness.
Andrew
Old Feb 25, 2017 | 09:41 PM
slogo's Avatar
You could always get a wire harness from wrecking yard and do it yourself and spend
that money elsewhere. http://lt1swap.com/wiringharness.htm
