Compression test
Old Mar 8, 2017 | 02:03 PM
33willys's Avatar
Default Compression test
When doing a compression test is it OK to just unplug the coils?
Old Mar 8, 2017 | 02:07 PM
socal57chevy's Avatar
Yup. Unplug the coil primary side and the injectors...and remove all spark plugs for more accurate results.
Old Mar 8, 2017 | 02:55 PM
33willys's Avatar
Default compression test
Oops, forgot abut the injectors. Getting the $%^& boots off is the hardest part. Anyone got a quick solution for that?
Old Mar 8, 2017 | 04:58 PM
Be sure to use a little dielectric grease when you put them back on. It will make next time a lot more fun.
Old Mar 9, 2017 | 11:32 PM
33willys's Avatar
Well, compression test done...150# on all. Pulled the fuses to the ECU, injectors and fuel pump made that easier than disconnecting the injectors. Hardest part was getting the plug wires off. Doc says they should scab over and start to heal in a week or two.
